Python method to find maximum I-beam
TotallyPlaneCrazy
Aerospace
Greetings, all
I am trying to code a Python script to find the largest and lightest possible I-beam to fit inside an airfoil, given a minimum Ixx requirement.
My method currently involves trying to fit the largest possible rectangle with all 4 vertices close to the airfoil coordinates within a tolerance, such that A(rectangle)/A(airfoil section) is maximum, A(rectangle)/Ixx(rectangle) is a minimum. So far I have generated some feasible options, but recently Python just complains that no valid solution is possible, despite CAD and my calculations proving the possibility
How would you approach this problem?
forgive me, but I think your handle perfectly describes this idea !
The flanges of pretty much every spar I've seen conform to the OML of the wing ... ie a rectangular spar doesn't fit a wing ... unless you're in a very small plane (like a kit plane, where expense may be more important ... though I have experience with this too, and the spar flanges have been non-rectangular).
But if you do pursue this, remember the thickness of the web is another design constraint.
You'd need a lot more constraints to get a satisfactory answer. A simple optimiser will always maximise the height of the web and the width of the flanges, but the resulting I beam will be misproportioned and will fail in unusual ways.
You know what? I'll just do this using Eyeball Mk.1, CAD, and classical calculations, with verification by FEM to follow.
