Heathrow power outage 3
Hoxton123
GB
i do now know what the substation voltages are, but one of the two transformers is completely burnt, and i guess they isolated the substation in order to fight the fire
Maybe some of the sparkies here can help, but it loks to me,from what I've been able to clean, is that these two TX are the A and B 275kV. The third on the right looks like an add on for local power distribution.
For street view it looks very much to me like there are no fire walls between these two. Is that normal? Bearing in mind this substation might be 50 years old.
Any other comments on spacing or design?
The latest ASCE 113 Substation Design Practice Manual has a chapter on different kinds of protection walls for collateral damage from explosions. Also most current transformers are designed for the cover to explode upward before the side wall panels.
And with decent protection you detect the fault and clear the transformer long before it gets to the interesting stage.
Fully agree to thermionic1. Askarel/PCB was by far more a curse than a benefit in regard to safety. But there are other fluids where at least no sever health or environmental risks are known although they are in use for several decades. I have worked on units of several 10 MVA using silicone oil thirty years ago.
Public hysteria.
Years ago, during the initial concerns about DDT, the public became aware of "Bio-degradability".
Almost every month the "Bio-degradability" of another potential contaminant was reported.
PCBs were/are very stable and do not degrade for centuries. The key is "Very stable". When PCBs were released, they found the lowest level and just sat there.
PCBs were heavier that water and so would just pool in the low spots of water bodies and then do basically nothing.
Then it was announced that PCBs were SLIGHTLY carcinogenic.
Wow. Carcinogenic and it's forever.
I was working at a plant that had about two millions of gallons of used oil that was contaminated with PCBs.
I was concerned.
A friend of mine was a chemistry PhD and head of NMR services at a large university.
All research departments sent samples to his department for analysis.
He was responsible for knowing the relative hazards and safe handling procedures for any substance submitted to his department.
He often interacted with the cancer researchers.
He was warned that some samples were so active that one drop on unprotected skin posed a 100% chance of skin cancer.
His advice:
The cancer hazard from PCBs is so slight that if you smoke, you have nothing to worry about from PCBs.
But beware of heavy oils.
Heavy oils are extremely carcinogenic.
The real cancer hazard was the two millions. gallons of used oil, not the 100 PPM of PCBs.
[Ironic Anecdote Alert]
A truck was transporting an old transformer on an Ontario highway.
The transformer was leaking PCB coolant.
A family was following in their car and over the miles their car was sprinkled with PCB coolant.
The family was given a replacement car. I don't know how the contaminated car was disposed of.
Miles of highway was repaved. I don't know how the contaminated asphalt was disposed.
Public Hysteria and misunderstanding versus science.
Public Hysteria wins every time.
Conventional transformer oil is slightly carcinogenic. Probably more so than the PCB coolants that it replaced.
Perception, misunderstanding and hysteria.
[Ironic Anecdote Alert2]
A number of a rancher's heifers gave birth to deformed calves.
Someone remembered that a capacitor station 10 or 20 miles away, had buried some PCB insulated capacitors some years before.
The burial sites were excavated and it was found that the capacitor cases were intact and there had been no leaks.
The investigation continued.
It was discovered that there had been an accident at a logging site the winter before.
A valve was knocked off of a diesel fuel storage tank and about 1000 gallons of fuel was spilled.
The ground was frozen and the fuel flowed on the surface until it found a small creek.
The creek was the source of drinking water for the ranchers cattle.
Diesel fuel is a strong mutagen.
The moral?
There are lots of things in regular use and to which many persons are regularly exposed that are far worse than Poly-Chlorinated-Biphenols.
I suggest that the repaving created several thousand times the cancer hazard that was posed by the original sprinkles of PCB.
Final report issued.
Scroll down to find the actual report.
Failure of a bushing due to water ingres.
Also Heathrow takes 10 to 12 hrs to reconfigure their internal systems. Apparently this was "not well known"....
To be honest half of the "oh bollox" aviation issues are due to water, pee, sweat or some other condensate fluid.
I expect the air India to have it involved.
Exploding hydraulic pump on a Jetstream 31. Water in hydraulic fluid boiling creating steam and corroding the pressure sensor and bypass valve . Resulting in the pump pressure going over 8000psi from the norm of 3000psi. Huge bang and big white cloud, no fire thankfully. FO new pair of underwear.
AIBB UK explain your command decisions.... It went bang hydraulic pressure lost again.... Wales got a golden shower
Failure of a bushing due to water ingress.
So the basic summary seems to be:
Water detected 7 years ago, but the replacement of the bushes was not undertaken and maintenance postponed. No one seems to know why...
The site was built prior to better segregation and fire walls, yet remained in service and no apparent attempt made to upgrade that protection or raise the site to one of higher risk.
The fire suppression kits installed were apparently out of commission for over two YEARS before the fire(!)
The second and third TXs continued to supply power for another 30 minutes after the first one caught fire, causing issues for the fire crews now stationed outside.
The grid operators had no idea how their supplies were connected inside Heathrow
Heathrow knew a power supply outage would take 10-12 hours to reconfigure the connections and supplies and then check and restart equipment which has powered down, but considered this event to be very low probability.
Heathrow though managed to decide to shut the whole airport only 1 hour 20 minutes after loss of power from the substation. It then took them the 10 to 12 hours to re connect everything based on two of the three incoming power supplies.
So basically 60 year old infrastructure with inadequate fire separation or suppression and internal connections within Heathrow taking far too long to reconfigure to the loss of what they considered to be an "uninteruptible" incoming supply.
People making the decisions to not do anything about the water ingress and other things should be fired. Completely incompetent and just lazy.
Attached are the internal Heathrow report (Kelly report) and the final NESO (National Energy System Operator) report.
it seems that Heathrow assumed that the supply was always assure of connection...
The failure seems o have resulted from known moisture ingress to a 275 kv transformer bushing. it all went downhill from there...
