NX Journal: Turning Expressions into Labels 1
GiantIsopod
Hi all,
I'm trying to make an NXOpen program using VB that can loop through expressions in a part, and, if applicable, create a label at the associated location. I can both find expressions and make labels (each individually), but as far as I can tell there isn't an easy way to get an expression's location... only its "source." I am fairly new to NX so truly any kind of help would be greatly appreciated. I have been browsing the NXOpen documentation and it seems like maybe Annotations.PmiLabel could be helpful(?) but I really don't know.
Thank you!!
Here is some code I have to determine if an expression is present. I know it's not much, but it's a start.
Imports System
Imports NXOpen
Imports NXOpen.Annotations
Imports System.Windows.Forms
Module PmiNoteExample
Dim theSession As Session = Nothing
Dim workPart As Part = Nothing
Sub Main()
Try
' Initialize the NX session and work part.
theSession = Session.GetSession()
workPart = theSession.Parts.Work
Dim displayPart As Part = theSession.Parts.Display
' Create an undo mark for the session.
Dim markId1 As Session.UndoMarkId = theSession.SetUndoMark(Session.MarkVisibility.Visible, "Expression")
' Look up the expression
Dim expression1 As Expression = CType(workPart.Expressions.FindObject("A2"), Expression)
If expression1 IsNot Nothing Then
Dim outputMsg As String = "Found Expression: " & expression1.Name
theSession.LogFile.WriteLine(outputMsg)
MessageBox.Show(outputMsg, "Expression Found")
Else
Dim notFoundMsg As String = "Expression 'A2' not found."
theSession.LogFile.WriteLine(notFoundMsg)
MessageBox.Show(notFoundMsg, "Expression Not Found")
End If
Catch ex As Exception
Dim errMsg As String = "Error encountered: " & ex.Message
If theSession IsNot Nothing Then
theSession.LogFile.WriteLine(errMsg)
End If
MessageBox.Show(errMsg, "Error")
End Try
End Sub
End Module
What is the LOCATION of an expression? They are not graphically displayed objects. It is table like data.
"...but as far as I can tell there isn't an easy way to get an expression's location..."
An expression itself is not a displayable object, thus it has no location. There are point expressions that can hold coordinate data that represents a location in the part, but again, the expression itself is not displayable and has no location of its own.
Can you explain more of what you are trying to accomplish?
Basically what I'm trying to do is help move towards Model Based Definition. I need to get all my expressions labeled on my model via balloons or labels with at least some automation (maybe a program feeds the user an expression and the user inputs it?) Again I am new so any and all ideas are super helpful.
so for each expression you want to see if it is linked to a feature? and then use that feature "location" as the label origin? Example would be a BLOCK feature. There are 3 expressions. You want to create three labels for each expression at the same point?
Also there maybe no be a generic LOCATION for various features. yet you could take a POINT on the feature data of bodies and sheets and curves. Datums axis and planes you might need to edit the feature to get some location point
I see what you mean. Working with expressions in this way is much harder than I thought! I am curious as to other ways I could use expressions to move my NX models toward a MBD system... I was previously thinking I could get bubbles on each expression via automation/NXOpen but that seems like a stretch given my current skillset and what people in this thread have stated.
I now am thinking about making a program that:
1: Reads all the expressions into Excel sheet
2: using a Windows window/output, show the user each expression by name and copy that name to the clipboard
3: user makes a bubble or label appropriately, pasting the name.
4: User can click "next" in the window to be given the next expression to make a label for
So it's less automated and more like a guided system and you're just fed expressions to label one at a time, or maybe skip unnecessary ones.
Again thank you I appreciate all the help.
It sounds like you should look into Product Manufacturing Information (PMI) annotations to fully define your model. Expressions, by themselves, do not fully define your requirements; they do not capture info such as datums and tolerances, for example.
The video below is a quick introduction to PMI in NX.
i am still confused on the purpose of this, MBD is to me transfer ( to the reader) info on how the geometry looks and how to manufacture/ tolerances etc, the feature buildup can be a completely different story, and not necessary a good one either..
NX is maybe the most "allowing" cad system, it allows the user to do things as the user wants, and few restrictions.
Imagine importing a solid via Step/ Parasolid/ Acis/Dwg etc you get a "dead" solid body, if you then change the shape using direct modeling etc, the few expressions from these features will not tell much about the model, only some changes done to "a block of clay".
