GE Vertical Motor - Spherical Roller bearing with springs
RM12
I have been trying to test run an induction vertical motor with spherical roller bearing on the NDE. This bearing is inside a cartridge under which there are springs. The entire assembly goes inside the bearing housing. The DE has a deep groove ball bearing (guide bearing). The axial play was set to 0.008- 0.010 ".
During the test run (unloaded) the vibration amplitude seems to be cycling between 0.13 ips to 0.44" ips in a span of 15 mins and all at 1xRPM (1800). The phase angle of unbalance does not change by much (270 -284 deg)
What could be the cause for this? What is the testing procedure OEM follows to test run this motor unloaded?
@RM12 Is your vibration in the radial or axial direction?
More details on vibration in the following links.
It is radial
