dik
- Apr 13, 2001
- 26,106
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
because of the large amount of void.Why the "half the wind load value"?
Thanks JAE...I'm always temped to way over-estimate the effective area of things like these.
Not likely... get a Darwin award. I think I will use the full wind load.Can an athletic person jump up and grab a hoop?
I think the 'structure' is pretty stiff; I don't think dynamics will be an issue.There's potentially a bunch of stuff vibrating up there,
Your approach reasonable . I would go with component force coefficients and use the effective area and apply solidity ratio.I was thinking about using the area of the top with a wind load using half the wind load value
