Zone classification for sewage storage and packing system
seuenergy
Chemical
HK
Hi all,
We have one storage house for sewage. The design engineer want to classify the house as zone2 as there might be slight H2S generated by sewage.
As the house is equiped with forced ventilation( not sure if the ventilation rate reaches 6 times per hour), I can not argue with this zone 2 decision.
But I am wondering how much H2S could be generated by sewage to form an explosion environment? Does any one have some information for this? Thanks!
1/ Descrbe the sewage. Describe the house.
2/ What about underground sewer system and pump station - is it designed Ex-proof or not? Is the sewer system segregated?
3/ What is the sources of water? Is it process drains or a surface water drainage?
4/ Why H2S? Why not CH4 or HC?
5/ Do you understand that H2S acute toxicity threshold is much lower than LFL? One will definetly die from intoxication prior being exploded.
6/ What for is sewage stored and packed?
You need to share much more details related to obtain a valuable reply whether you concerns are real or not.
For info - whether water can exlode
EI 15
3.6.5 Surface water drainage systems
Oily water and chemical sewers can become contaminated with flammable fluids during normal operations, and openings to atmosphere should therefore be regarded as sources of primary grade release.
Normal open surface liquid drain channels, typically not more than 0,5 m wide, handling flammable materials should have a nominal hazardous area of 1 m horizontal radius each side and 1 m radius vertically above them. Where there is a possibility that a hot material (e.g. category C fluid above 50 °C or steam condensate) could enter the drain in sufficient quantities to produce an appreciable flammable vapour, or that category A or B materials could inadvertently enter, these distances should be extended to 3 m.
The vaporisation rate from any vents on drain systems should normally be low and a Zone 1 hazardous area should be drawn in accordance with Table 3.2 assuming a vent rate of not more than 10 m3/hr at ambient conditions.
The possibility of abnormal releases (e.g. hot water) entering the drains and the vaporisation of volatile liquids should be considered. Based on this it may be appropriate to define a larger Zone 2 area for the vent using dimensions given in Table 3.2 consistent with the higher vapour emission rate.
The possibility of vapour release should always be considered when access chamber covers are lifted or temporarily removed.
Note: Drainage systems for distribution installations should be designed with consideration given to the principles detailed in EI Model code of safe practice – Part 2: Design, construction and operation of petroleum distribution installations and EI Environmental guidelines for petroleum distribution installations. In the case of filling stations, the design should give consideration to the principles detailed in APEA/EI Design, construction, modification, maintenance and decommissioning of filling stations.
Hi Shvet,
Thanks for your comments.
A: The sewage is from waste water treatment unit. The water concentration is around 80%. The house is well enclosed with HVAC.
A: There is no pump inside the house. The packing equipment inside the house are designed as Ex-proof.
A: Sweage contains water when it is transferred from waste water treatment unit.
A: H2S is generated by sweage for long time storage.
A: Sweage is packed for transporation to exteranl treatment plant.
You must have continuous monitoring of H2S! Please review your MSDS or toxicity sheet for this material.
Should be an open space.
It's heavier than air.
Pierre
Pierre
Hi Pierreick,
Yes, Continuous monitoring by two H2S detectors inside the house.
Make sure the sensors are calibrated properly, at the right thresholds.
What are the actions in case of concentration high?
Hope you did a safety review.
Definitely a dangerous area. Operators should have a portable sensor all the time with them.
Based on my experience 10 years in soda ash plant.
Pierre
Pierre
Hi Pierreick,
Thanks for reminding.
We have gas detect monitoring system for these detectors.
What I concern is that whether this room should be classifed as zone 2 or not.
HI,
Should be :
Zone 2 is a place in which an explosive atmosphere is not likely to occur in normal operation but, if it does occur, will persist for a short period only. These areas only become hazardous in case of an accident or some unusual operating condition.
For reference:
Pierre
Still lack relevant information.
1/ this is not sewage. It is called sludge. What is the origin of this sludge? Is it municipal wastewater? Surface water? Process? Froth from a flotators? Aeration tank sludge?
2/ municipal sludge produce more CH4 than H2S. Typical ratio is 150:1. Why do you concern of H2S explosion hazard? Because there are toxic gas detectors in the building? Why there is no methane detectors?
@seuwnergy, why are you keeping avoiding sharing the details? Do you believe those are not relevant? Is it a classified premises?
Yes, you are right. It is sludge. These organic sludge is from aeration tank.
The information from designer is that these organic sludge could generate H2S, and that is why they calssify the zone as zone2. The room is equipped with H2S detector as well as LEL detector.
I am not from the unit. So I need to get the information you have required from designer or plant owner. It takes some time for collection. Sorry for the late reply.
Organic biomass is always a source of methane as a result of anaerobic biodegradation. Given that the sludge is stored and packed in an oxygen-depleted atmosphere, it does generate some methane contaminated by H2S and CO2.While methane is inert to the human body, H2S has an extremely low acute toxicity threshold. This is the reason why the premise has some H2S detectors.The methane generation rate is rather low to lead to an explosive atmosphere, but it is lighter than air and is prone to accumulation in stagnant zones; the most common place is under the ceiling. This is the reason why the premise has LEL detectors, I guess intended for methane.
You are right - there are no reasons to design the whole space of the building or the premise space as an Ex-zone, as there is no chance that methane will displace the air and occupy the whole space from the ceiling to the floor. But some space should be, given that methane can migrate from interconnected equipment or a process upset can lead to rapid methane escaping from a process containment. Guidance should be found in the applicable safety code; you should contact the local safety inspector and find out how code compliance is supposed to be confirmed. The industry-recognized guidances for Ex-zoning are: EI 15, IEC 31610 60079, API 505. As per my experience, this limit is 1/4 of the premise's volume; this limit may be applicable to your case or not, depending on the local codes and practices. Note that many large end-users develop proprietary guides/plans/instructions for ex-zoning procedures.
If you do not understand what I am talking about, you should leave this task, as Ex-zoning is challenging and site/case-specific.
For info - whether anaerobic biogas accumulation is dangerous
Hi Shvet,
Thanks for your explanation. These information is important.
I am not leading the work, but try to learn something during the work.
Refer to NFPA 820 table 6.2.2.a row #13
The Ex-zoning is not mandatory given the condition that the cake handling space is continuously ventilated at 6 air changes per hour.
Otherwise the entire room shall be designed as zone 2.
Hi Shvet,
The room is equipped with HVAC system, and continuously ventilated at 6 air changes per hour.
