EngDM
- Aug 10, 2021
- 771
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
EngDM: I'm thinking @JoshPlumSE is on the right track, but this is a pretty typical W column baseplate with only 8 anchors, so not sure why they'd need this; they could cut a simple template out of plywood and use that as their reference.
Does this have any effect on the pryout resistance at the top of the anchor for shear?That looks like the typical Portland Sleeve detail. Those are mainly for alignment. They are ribbed so they do not crush as the concrete is poured.
Agree, alignment is one thing, but they are also used to increase stretch length when an anchor needs to be preloaded. Very common in the oil and gas industry when you have tall vertical vessels or large vibrating machinery.That looks like the typical Portland Sleeve detail. Those are mainly for alignment. They are ribbed so they do not crush as the concrete is poured.
