I have an exterior second story wood deck and need to replace the existing 6x12 (22' long) wood beam. I like to use redwood beam to prevent dry rot issues. The only available beam type in our area is 6x12 redwood, con-heart grade. For design, I need the allowable bending stress for the 6x12 redwood beam. The Codes (i.e. NDS and UBC) do not have the bending stress listed for members thicker than 4" (see attachment). Any idea where I can get allowable bending stress for 6x12 redwood beam. If nothing is listed then I have to use glued-laminated beam, and in that case, how do I make sure that the beam is rated for weather exposed area?
