Hey all,
For a typical steel channel stringer with welded angles to hold FRP or metal grating, would you typically size these as fully unbraced or rely on the grating to brace it? I'd imagine that since the channels are typically mirrored with the toes facing outwards, that they would buckle in opposing directions. Is this enough to consider it braced, since they'd be working against eachother? Are you then required to check each channel for out of plane bending due to the other channel buckling? The grating connection itself would need to be sized for that brace load, but I've never checked the grating in compression.
I've mostly dealt with shorter stringers where length isn't really a consequence, but for this one I've got a large 8m (32° angle from horizontal) stringer with a cranked mid-height landing that'll get CJP welded. Taking fully unbraced for that length on a channel just tanks my capacity.
I'm thinking it would work similarly to a typical box girder crane, but I'm not sure if those are sized to brace eachother.
