SCBF embedded on IMF
X4vier
CO
Is a SCBF embedded in an IMF accepted as a Dual system?
Or they should have different locations to be accepted.
Define your acronyms, if it's not TMT. ( too much trouble)
I don't believe you can do that, but I'm not 100% sure.
Is a Special concentrically braced frame (SCBF) embedded in an Intermediate Moment Frame (IMF) accepted as a Dual system as per ASCE 7?
That is not a dual system. That's something you've made up.
A dual system has discrete shear walls or braced frames combined with discrete moment frames both acting in the same direction but in separate locations in the building. They are not some combined Frankenstein frame.
I'd recommend you get the book by Steve Hiner for a better understanding of seismic force resisting systems and their selection.
why would you want to do that? it would basically just act like an SCBF with unnecessary/expensive detailing for the moment connections
The referenced book is "Seismic Design Review Workbook"? Hehe.. Frankestein.
Not a lot of space to put braces (just exterior walls allowed).
SCBF is not accepted by local code (R-001 from the Dominican Republic)
Yes.
If SCBF are not allowed use whatever is...special moment frames, eccentric braced frames, or something else.
