Install Difference Voltage Rating 24 kV to 13,8 kV
thepo
Is it ok to install Pole Mounted Recloser 24 kV to 13,8 kV distribution system?
The control voltage will be wrong. Depending on the make/model, you may be able to add a VT to correct.
Yes need use different VT, how about the overhead Recloser, still works?
