Replacement for the old Mathcad
Ussuri
1,582
Further to the thread below looking at alternative calculation software, I stumbled across another possible contender call Tech Editor.
I haven't tried it but the website blurb sounded promising. Unlike SMath, which is Russia based, this one appears Ukraine based.
Mathcad Prime
Maple Flow
Smath
Calcpad
Blockpad
Plus things like
Excel
Matlab
Octave
Python/Julia (Jupyter)
wxMaxima
I have had some success in getting ChatGPT to write Matlab/Octave scripts, and dystr.com is an integrated AI /Python environment. However, neither can be trusted, and in once case they both made the same mistake. They do however produce simple and well commented code. which can then be corrected by hand.
This is typical of the sort of nonsense they throw up. No amount of 'correction' will actually get to a correct script, they just apply bodge after bodge
Dystlab is primarily a documentation generator, with a math engine. Its operation is all hidden inside "math" objects, so using it as a calculation worksheet seems cumbersome and awkward, to me.
I looked at BlockPad. It appeared promising, but I am too far down the Excel rabbit hole to climb out now.
I jumped to Maple Flow from Mathcad 14. For an old Mathcad die hard (on the wrong side of 60), it's been a learning curve. It's different but good different.
