yamoffathoo
- Sep 19, 2008
- 89
I would like to determine the effect on natural frequencies in bending by adding incremental layers of a composite wrap to the entire length of a stainless steel tube.
For this application, the tube is simply supported at one end and anchored at the other with uniformly distributed mass of just the composite assembly.
The stainless steel tube has the following properties:
Inner Radius = 0.185”
Outer Radius = 0.25”
Young’s Modulus = 30,000,000 psi
Poisson’s Ratio = .27
Density = .289 lbm/in^3
The composite wrap has the following properties:
Inner Radius = 0.25” (same as outer radius of tube)
Young’s Modulus (Circumferential and Axial) = 5,662,000 psi
Poisson’s Ratio = 0.091
Density = 0.0683 lbm/in^3
a single wrap thickness is 0.051"
Roark & Young 5th ed shows how to do it with beams by developing the equivalent width technique within the proportional limits for all materials, but I haven't found a method for hollow circular sections.
FEA is an option but I was hoping to apply TkSolver and its iterative equation solution capability.
