StanMan122
I've been searching EVERYWHERE for a simple formula to calculate 2 unbalanced loads on a 3 phase line. This is an issue when calculating FLA on machines. i.e. If I have 3 230vac, 2300watt single phase heaters across the three phases, no problem. P/E * 1.732. If only two heaters of equal wattage, no problem. P/E = I in the uncommon legs, I * 1.732 in the common leg. The problem is when I have 2 heaters of different wattage. If one heater is between Phase A & B and the second is between Phase B & C, what is the current at Phase B? I found one formula, but it must be worng because my result on Phase B was greater that I * 1.732 of the higher wattage heater. Unfortunately, the formula is at work and I am at home. To the best of my recollection, the formula was something like :
(((Ia + Ic)^2) + (((Ia + Ic)^2)*.866))^.5
Again, I think the formula was wrong. Perhaps a typo somewhere. Anyone know what the formula is???
Any help would be greatly appreciated.
