It seems nobody makes a shaft coupling that steps down 1/4" from 7/8" to 5/8". I am looking for a clamp-style coupling. Hooking up a gearbox that has an output shaft of 7/8" DIA with a 3/16" keyway to a ball-screw setup that has a shaft size of 5/8" DIA with a 3/16" keyway. Any ideas of someone that makes one that can handle these sizes, with or without the keyway? Thanks.
