I believe that ScottyUK is right when he says "it depends." You really need to consider Blondel's theorem & it's errors to determine the answer.
Blondel's theorem states that "If energy is supplied to any system of conductors through N wires, the total power in the system is given by the algebraic sum of the readings of N wattmeters, so arranged that each of the N wires contains one current coil (transformer), the corresponding voltage coil being connected between that wire and some common point. If this common point is on one of the N wires, the maeasurement may be made by the use of N-1 wattmeters."
So if you research, you will find 2-element, 2-1/2 element, & 3 element meters. The element is the number of PTs & CTs where for example, a 2-1/2 element is 2 voltages & 3 currents.
The 2-element & 2-1/2 element will introduce errors if the system is not symmetrical/balanced but it depends on your reason for metering & if you can live with these errors.
There are numerous manaufacturers of industrial grade meters. I personally like the SEL-734 for the cost & features.
