Paper Space v. Model Space and Scale
I am sorry to post such basic questions, but could someone tell me what is drawn in paper space v. model space and if there is any reason not to drawn in full scale.
Finally, is there a drawing standard out there that spells this out?
Thank you
Thank you
RE: Paper Space v. Model Space and Scale
2) always draw your "thing" in model space
3) use paper space for your border and create viewports to the model. Put all dimensions and text in paper space.
4) Autocad help can help, there are lots of books out there
Calif
The resisant virtues of the structure that we seek depend on their form; it is through their form that they are stable, not because of an awkward accumulation of material. There is nothing more noble and elegant from an intellectual viewpoint than this: to resist through form. Eladio Dieste
The worst thing about putting dimensioning and text in model space is alternate views. I did a series of printouts recently where I started with a township view of roads and pipelines, zoom in and you see a facility plat, zoom in further and you see a tank connection detail. I know there are any number of ways to do this, but by putting the dimensioning and notes in paper space, everything was drawn exactly once in 3-d so that when I wanted to show how two tanks connected together I put them in an ISO view in one of the layouts and it worked perfectly. Change management doesn't get easier than that.
David
I have my title block in paper space.
I dimension everything in model space. I have a drop down menu with set viewport scales. When the viewport scale is determined, I have a drop down menu to override the overall scale in dimension style to match the viewport scale selected. If you scale your viewport, you can select the proper dimension scale from the drop down menu and use dimension update. That way you can have multiple viewports that have matching text size. I also think it is easier to dimension in model space. If you notice something isn't right with the drawing, you don't have to flip back between paper and model space.
Ian
I recently picked up a contract job and the company uses layouts for printing. I haven't used layout for a long time. I use AutoCad 2004.
Can someone provide with an example (step by step) as to how this layout works? I have drawn the object (to scale) in model space (including dimensioning it). The company has provided me with their co. template (saved in .dwt) they use in the layout. When I select, the layout tab, the object does not appear. I have to create another layout in order for the object to appear in the view port. What am I doing wrong?
Darlene
Controls/Automation Technologist
1. Make a layer for the viewport (e.g. "vport"), make it no plot and set it current.
2. While in the layout tab start the mview command, make the rectangle the approximate size you want; it can be adjusted later.
3. After you pick the 2 corners for the viewport rectangle the model space will zoom to extents. Double click inside the viewport to make it active. The border of the viewport should bolden to show that it is active
4. Start the zoom command > center, pick the approximate center of the model. When it asks you to specify the height type in 1/50xp (for 50 scale, adjust to your needs). The model will zoom to the appropriate scale for plotting 1:1 from paperspace.
5. You can pan around to center the model as needed.
6. Once you get the model where you want it type in mview again > lock > pick the edge of the viewport to prevent changing the viewport scale. This can be done in the properties dialog box also.
____________________
Acad2005, Terramodel
vtgobbler,
it is easier to draw in 1:1 because you wont need to convert all of your measurements. text is scaled, however, to the paper size, not the drawing size. you can have multiple paperspace settings (print settings) for dif sized paper and have all the same size text so it is readable
zdas4: I use paper space to place my title blocks and borders, so that's not a problem. I'm not sure I folow the rest of your statement though. I never work in 3d so i can't really comment on that.
Darken99: I use the same method in my drawings. HOWEVER, I'd like to find out more about the tool you use to match dimension styles based on the viewport scale. Is that a lisp routine?
Iamjonscranium: are you stating that you also add dims and text in model space? Maybe it's too late at night for me to be reading this stuff...i just can't follow anyones thoughts.
Thanks to everyone for the feedback!
