Static billboard design structure
Hi
I need advice on a 6m x 3m static billboard design
1. Foundation type? Alternative to achor bolt system
2. Will 100 x 100 6mm sq tube steel do. How many post recommended
3. What type of backing board should I use
Any other suggestion will greatly help
RE: Static billboard design structure
2. Calculate the wind load; multiply by the moment arm, compare to the bending capacity, and find out.
3. One that's strong enough to resist the wind load, and won't degrade due to the weather exposure.
