Hello, new of the forum, thanks for having me.
I am designing a 10m Diameter tank, 10.2 high.
I am a bit stuck on the roof-to-shell joint.
The last course is 8mm and I have chosen the minimum top angle profile (75x75x8).
Now, here's my problem: when I calculate the minimum participating compression area I follow fig. 2 for detail b.
I get 4,300mm2, which is impossible to achieve with that top angle.
Am I doing something wrong? the area of the top angle section is 1000mm2 and I will never get the missing 3000 with a roof 10mm thick and shell 8mm thick.
THanks for you help
THanks for you help
