Fire Pump Motor
Erfan z
FR
Hi, fellas
one of our client's inspectors engineer insists that the screw(shown with a yellow circle in the attached picture) is missing and don't accept use in the project.
so is there any technical explanation for why this screw is not exist there?
also that the other side of the motor has this hole without a screw in it!
almost all of our purchases from this brand have this feature but this is the first time we faced this question!
What did the motor/pump mfg say? It is the only explanation I would accept if I questioned it as the AHJ.
Is it threaded ???
Same comment as lcrep
Maybe a mount for an accessory,,, you do not need?
@LCREP manufacturer of electro-motor doesn't reply to my emails!
if you have Marathon Electrics technical support email, please share it with me.
thanks a lot.
@cdafd Yes it is threaded
there is no accessory with the electro-motor or standard requirements to mount an accessory!
Did you try calling them??
United States
Customer Service: 1-833-734-2500
Regal Rexnord Corporation
111 W Michigan St
Milwaukee, WI 53203
Phone: (608) 364-8800
Fax: (608) 364-8816;
