Standard Tap Specifications / H3 Taps
paulcook
Would you consider the following tap "standard" - i.e. yielding a class 2 fit?
Pitch Diameter Limit H3
Is it on the loose side, the tight side, or just what is used most of the time?
Thanks y'all
Paul Cook
Buy a used copy or new machinist handbook.
It's a very valuable info on stuff like this.
And a copy of the latest thread specification.
Always have a set of go and no go gages.
When drilling and tapping. The gages will verify Size is correct. You need the correct PD size .
Thanks for the resource
