Special Concrete shear wall design
shacked
It has been a long time since I have designed a concrete shear wall since the majority of my work is in light framed residential. Last time I did was in 2010 or 2011 and I know that there has been some major changes with the code with respect to slender concrete walls. Unfortunately, I have not kept up with the changes related to this.
Now I am working on a project and the scope of work has changed due to owner changes. These changes will require concrete shear walls and I am considering whether or not I should continue as the EOR.
I wanted to see what the code requirements are for these walls so after looking into the code as well as some initial calculations I am now looking for advice.
I use TEDDS for my software and they have a concrete SW module so I decided to see what the calculations would involve. Unfortunately after I input the design info, I get a message that says, the bresler reciprocal load method is not valid.
Do you think is would be possible to provide these calculations by hand? If so I would assume that SEAOC may have some design literature available? See pdf for plan and section of project.
Your thought are greatly appreciated.
 https://files.engineering.com/getfile.aspx?folder=bb906ec5-5d70-4d28-909b-3e13c6753599&file=GARAGE_PLAN.pdf
SEAOC has some design examples that you could follow if you have access to them. The most recent from SEAOC would be the 2021 IBC SEAOC Structural/Seismic Design Manual, Vol. 3. Be aware that the ACI318-19 has some new provisions for special concrete shear wall designs that differ quite a bit from the previous versions. Make sure to read through the design and detailing requirements.
If it has been 13 years since your last foray into concrete, I would say definitely find a design example to follow from the current code to help you avoid the common mistakes.
Best of luck!
"Let me help you by not helping you."
Thanks guys, I appreciate the info.
