Designing a quadcopter powertrain.
Jack_the_JOAT
Hello All
I am working on a power train for a quadcopter - see attached the PDF.
I am wondering about the gearbox for power transmission, guessing its a bevel gear design.
I would like to keep the belt drives on the same plane.
Also, should I step the RPM down from the motor to the drive shaft? Thinking a belt or a direct geared connection might be best.
Or step the RPM down when I transfer to the belts?
Can anyone advise on what this might be called and maybe a manufacturer?
Thanks in advance.
Jack.
 https://files.engineering.com/getfile.aspx?folder=a04536b1-8f72-401e-977b-db6dcec856db&file=Rotation_Schematic.pdf
You need to have some type of independent speed variation for each rotor, for control. Most quad-copter stuff I've seen (mostly drones) use individual motors for each rotor.
