GD&T Question
Qcprick63
Industrial
Not a fan of this type of callout.
I ran a circle at the far edges of both bores then recalled into a 3d line . Put a few more circles on both diameters and asked for runout back to the 3D line. I guess I report the highest runout value? Is that correct or is there a better way??
I am not comfortable with the length of the A and B datums relative to their diameter and proximity. But yes I would approach it as you are - build a best fit 3D line across the entirety of A and B and report each bore runout to that 3D line. I'm not enouhg of a GD&T wonk to explain which rule this violates other than common sense.
Or put A and B as a circle at the middle of their features and make A-B using those two circle center points.
Regardless, I would clarify on the inspection reports which method was used.
sorry, it wasn't getting any responses in this catagory.
