CSI Bridge - Per Lane Responses/Output
The_Terminator
Good Evening!
I am wondering if anyone familiar with CSI bridge is familiar with 'Per Lane' live load responses from the program, specifically for bearings/links? This is the first time in CSI that I have tried to obtain this kind of response, so I am not sure if there is some way to obtain this? Essentially, we are trying to obtain the reactions at supports but need these reactions to be in a 'per lane' output, not the max reaction, since using the max reactions for all girders would be very conservative. I am not aware of any direct bearing output from the bridge object model, so I am assuming that this information would need to be obtained from results tables for the links somehow. Any suggestions or advice would be much appreciated.
Thank you!
Carl
