Rental Skid Condensate Stabilization Unit
faizizz
Chemical
SG
Hi guys, do you have any information or experience on having rental skid of condensate stabilization skid unit. Would be really helpful if can share the vendor supply name and where is the location it installed.
These things can probably be found everywhere.
Where do you want to put it.
No sense transporting it from Bolivia, if you want it in Iraq.
I dont have these contacts, but it would be better if you also state what type of condensate stabilisation you are looking for.
Flash stabilisation may consist of 2 stage separation with intermediate heat exchanger. Poorer recovery of C4plus. Quicker to build.
Stabilisation with a column gives you better recovery. Better recovery of C4plus
Also state what is required TVP of C4plus liquid product, type of vapor handling system you've got for the MP and LP flash vapors.
Contaminants in the feedstream such as H2S, methanol will complicate matters.
