Machined Screw Strength and Hardness
Some help please with a newbie question. If I machine a big screw, will it retain it's strength and hardness? Does it have the rated strength and hardness throughout it's thickness or is it softer in the centre?
For example: Using a lathe, I turn down an M20 bolt to have a shoulder with an M10 thread on it. Can I assume the M10 section would retain the rated strength, e.g. grade 8.8?
I am asking this because I am unsure if machining will produce enough heat to remove the hardening/tempering, as is the case with welding. Thank in advance.
RE: Machined Screw Strength and Hardness
b) if you machine it, pay very close attention to the fillet radius at the shoulder transition, and to the new thread runout before the shoulder. You could easily end use with a nasty stress concentration.
It’s not something I have thought about before but providing the heat generated doesn’t exceed the temperatures of the original heat treatment I would of thought it’s mechanical properties would be unchanged, however if the screw thread was originally cold forged and you machine it, then that might be a different story. Can you please expand on why you need to turn a larger screw down and what is the application?
Does anyone know if the heat generated during machining is high enough to alter mechanical properties of bolts? (Consider for example stainless steel which generates high surface temperatures during friction movement) Perhaps @EdStainless might know?
I'm thinking :
- a spacer on COTS screw/bolt
- a COTS shoulder screw ( although a quick search for an M10 thread did not come up with shoulders over 14 mm or so)
- cut the thread off a long M20 screw with a shoulder/shank accurate enough for your needs. Leave the shoulder/shank the length you need. Then drill and tap the end of the stubby screw M10 20 mm deep, and install a 40 mm long M10 with red loctite.
It is the fact that most fasteners are not the same strength throughout.
The cores will tend to be softer, and sometimes a lot.
If you are using an alloy such as 4130 that has been Q&T, then you are likely to only loose a few points HRC by removing 5mm of material.
If the threads were rolled then you could be losing closer to 10 points HRC.
None of these would work?
https://www.mcmaster.com/products/stripper-bolts/t...
https://www.mscdirect.com/browse/tn/Fasteners/Bolt...
https://us.misumi-ec.com/vona2/press/P0300000000/P...
Yes Ed, those shoulder bolts definitely would do the job. I was just curious.
