Hatch selection with selection filter
BorisLevin
Can Area Hatch/Fill be selected with selection filter? I am working in solidworks with DXF files, a lot of hatched areas, Time consuming to select every hatch.
Try layers. If a DXF, the layers probably came with it. Turn off layers that are not hatch, then delete as needed.
Chris, CSWP
SolidWorks
ctophers home
As a DXF file, I am sure the hatch lines are just sketch lines now and not the actual SW Hatch entity. If so, then you need to just use a sketch line filter instead and use the window selection of the hatch lines and remove. YOu will have to be sure not to grab an object line that is needed.
Scott Baugh, CSWP [pc2]
Mechanical Engineer
Ciholas
"If it's not broke, Don't fix it!"
faq731-376
