Contact US
pipeline hydrotest
3
pipeline hydrotest
pipeline hydrotest
Hello everyone! Could I use gas instead of water for a hydro test on 46" crude oil transportation pipelines, considering the requirements of API 1110?
thanks in advance.
RE: pipeline hydrotest
Hani,
If you are involved in making decisions on a 46" crude oil pipeline YOU SHOULD NOT BE ASKING FOR ADVICE ON AN INTERNET FORUM,
Shane
What design code are you using?
What test pressure?, usually 1.1 x DP.
What does it say?
I've never really used API 1110 despite decades in this industry so not sure what it says. But it is an RP, so not as prescriptive as the code.
We've discussed this many times before in the pipeline forum e.g. https://www.eng-tips.com/viewthread.cfm?qid=112658
do a search for "pipeline test in air"
That's a large pipeline and will contain a fair amount of energy which if the pipeline fails could result in a significant crater. you would really need to do your homework on looking at the impact of a failure, whether you can create an exclusion zone ( prob >100m ) / stop vehicles crossing it, that sort of thing.
Many codes and companies and safety authorities won't allow it.
If safety isn't a concern, go for it....
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
News
