I have a gap of interest in an RSS tolerance loop that involves two loop items that can each be filled with one washer minimum and three washers maximum. The number of washers needed will depend on system installation tolerances that are not part of the tolerance loop being analyzed. Is it correct to assume the loop items can treated as varying from the value of one thin washer to the value of three thick washers? A thin washer is a standard washer produced at minimum thickness and a thick washer is a washer produced at the maximum thickness. A colleague suggested to analyze the gap three times with one washer, then two washers, and finally three washers due to the discrete thicknesses of the washers. This approach seems to remove the statistical variation of using one, two, or three washers. Is this second approach valid?
