Contact US
Truss cost estimates
I currently have a very light weight (less than pedestrian) modular steel bridge design. I'm trying to estimate its constructed cost, and could use your help/experience.
The bridge module comes in at just under 100 plf (pounds/linear foot). Steel is currently going for about $666/ton = $0.33/lb. Structural shapes are going for about $2.60/lb, except for angle which is about half that. But i don't know what constructed trusses are going for. The module should be produced in large volume, so i expect heavily robotic manufacture. I think open web steel joists are probably a good model (about same ratio of weld joint length to member length; also large volume).
Anyone able to share the going rate for open web joists ($/lb)?
RE: Truss cost estimates
We're seeing bid prices in the range of $4.00 lb for the structural steel for welded plate girder highway bridges; slightly less, maybe $3.50 for the steel for wide flange girder bridges. Of course, we're dealing in large quantities (100,000 lbs and up), but that includes erecting the steel, also.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
News
Close Box
Join Eng-Tips® Today!
Join Us             Close
