How to connect two solid sections tangentially in Inventor?
imti7
IN
1. In NX i used to join these two different sections using through curves or through curve mesh with tangent relation between each sections!
2. In solidworks i used to connect these helical thread using 3D arc with tangent relation btwn edge and the curve then loft two sections using 3D tangential arc as a guide curve
I tried the same in Inventor, not happpening!!
Kindly tell me , how to perform same in inventor and i also have shared STEP file.
