Pet peeves (like open source for public domain)
What are your pet peeves about language usage nowadays?
For one, "open source" that is favored by the Pentagon and the press for "public domain".
Open source implies a double distinction: virally open vs proprietary closed licensing, and human readable source vs machine runnable object code.
It makes no sense for documentation.
"Public domain" as a phrase was already well established for the same for a long time.
(Did "open source" end up there just because it was a buzz word because of Linux and the GNU project? Side question.)
RE: Pet peeves (like open source for public domain)
Not all is going to hell but really. Percentage vs ratio must be clear.
"Suppressors" over legalese "Silencers" and the like. Centrifugal chargers over just all superchargers if they're not turbo but belt driven, that sort of thing.
Spoiler:
Ohm's law
Not just a good idea;
It's the LAW!
GNU Linux is Free Software. Free Software typically is not public domain, it is copyrighted, probably by some version of the GNU "copyleft". The language of the GNU "copyleft" emphasises all sorts of rights you have to use the software, but it does restrict what you can do with it. Typically, you cannot use it to create closed, commercial software.
Open Source means that you can see the source code. The software is still subject to a copyright of some sort, likely a commercial one.
Public domain means that there is no copyright control over the media. I understand that Mickey Mouse is now public domain.
JHG
I have to chuckle over "insight a riot," though.
My glass has a v/c ratio of 0.5
Maybe the tyranny of Murphy is the penalty for hubris. - http://xkcd.com/319/
I have no quarrel with either, but we don't force people to say, "5 times as much as" instead of "5 times more than"; given the latter, it's symmetrical with "5 times less than"
TTFN (ta ta for now)
Transiting to other usages:
1) the appearance of the word "like" in verbal communication where it is obviously just a placeholder.
2) the appearance of emojis and other symbolic short forms (UR anyone? instead of "you are"?) instead of actual correct language ... for this, I blame Toys 'R' Us.
3) the concept of a "sound bite". If something is being taken out of context, then it is open to interpretation. Can't be taken as the whole truth and nothing but the truth, so help me ...
Converting energy to motion for more than half a century
It seems like people are always trying to "insure" that something is taken care or, doesn't occur, is addressed, etc
what Open Source means is that the source code is *virally* open. Meaning, all derivative work must have its source code made available too. That's way more than just "you can see the source code". Open Source licensing is all about any and all derivative work in the future.
(I've read that Richard Stallman's original peeve was with a printer driver. A perfectly good piece of hardware was rendered useless for a lack of driver... and so it begun.)
My pet peeve was about using "open source" for (public domain) documentation, not computer software. Reports, studies, newspaper articles, that sort of everyday thing. These software related distinctions (virally open vs closed, source code vs object code) just make no sense whatsoever there. "Public domain" is what we're talking about there.
dik,
Indeed! PD software doesn't impose any viral obligations on what you do with it. You can build on the source code or just use the object code as you please. But that wasn't my point; I was talking about taking the phrase "open oource" where it doesn't belong, outside the world of software. Perhaps I wasn't clear.
open source is somewhat equivalent to copyrighted publications
public domain is equivalent to public domain - copyright expired
Banished Words 2024: for Misuse, Overuse and Uselessness
https://www.lssu.edu/traditions/banishedwords/
And here's this years list of the 10 words which they're advocating being banned from our lexicon:
John R. Baker, P.E. (ret)
Irvine, CA
Siemens PLM:
A futile attempt to distract the lay clerk from his catching up on the test score during the musical lull that follows the anthem.
or
A trite little homily on the trinitarian symbolism of the 8/5 trine; how late XIII century scholars considered that to be the perfect chord - and how much more perfect it would be if the outer parts could listen to one another and then maybe do something about the bloody tuning.
Thank you so much.
A.
I've never actually heard the latter used in 62 years of living in the US. However, I think the former is actually a better phrase, since "choir" is a much more commonly heard and used term and immediately brings up a vivid image of what the phrase means, while the latter word with "converted" does not, since "converted" seems to be a less common word.
Nevertheless, I think most of these are nits and are part of how a language evolves and changes over time; if the language police had their way, we might all still be speaking using "thee" and "thou" etc. The French actually do have a language police, and they have yet to snuff out "hamburger" and "le hamburger" shows up as the default translation.
At least in Romance Languages, the words are manageable, compared to spoken Chinese, where "electric brain" is the closest you can get to "computer" and "hand machine" is the closest you can get to "cellphone". Oddly, technical literature is often understandable without translation, since almost all of the technical terms are a bunch of English terms smashed into a sea of Chinese words
https://www.abebooks.com/9780380715435/Mother-Tong...
Irvine, CA
Siemens PLM:
I do have a few pet peeves related to the application of language:
1. Nitpicking/correcting others' words in an attempt to make yourself feel/look better.
2. Using trendy new slang at work. If the slang is trendy or new then odds are great that you're going to confuse most around you. If the slang is a generation older than you then its fairly safe to assume it'll be understood.
Only SOME engineers do that. I think you guys are also the ones that came up with "percent grade" instead of slope on roads, as if that's anymore meaningful than "slope"
Irvine, CA
Siemens PLM:
Leo Fender swapped the musical terms "tremolo" and "vibrato" on the electric guitars and amplifiers that bear his name. Admittedly a very minor issue, but still annoying to anyone who knows that technically correct is the best kind of correct.
‘I’m feeling gaslit by my own computer’: Why a small change by Microsoft was a big jolt for some users
https://www.cnn.com/2024/02/22/us/microsoft-defaul...
Disclaimer: Personally I couldn't care less as I've always used Helvetica as my default font on most all of my office applications. Now I can get away with using Helvetica as it comes standard on Mac's. Now it's been years (eight to be exact) since I had to use a PC and the Helvetica font was not available unless you paid extra for it since it's a proprietary font owned by the old Linotype company (now doing business as Monotype GmbH). However, Apple cut a deal years ago to include Helvetica on all Apple products, and since Apple computers were used so extensively by commercial artists, this contributed to Helvetica being one of the most widely used fonts in the advertising and publishing worlds, despite that fact that it's still generally not available on PC's. If anyone is interested in the history of fonts (AKA Typefaces) I can highly recommend the aptly name documentary 'Helvetica', by Gary Hustwit ('Helvetica' in one of his very highly acclaimed trilogy of documentaries that he directed from 2007 to 2011):
https://en.wikipedia.org/wiki/Helvetica_(film)
And speaking of Linotype machines, any engineer, particularly mechanical engineers, will find 'Linotype: The Film' very interesting (I know I did):
https://www.imdb.com/title/tt2130114/
Now getting back to this Calibri versus Aptos controversy, here's an example of the two fonts, along with Helvetica, as a comparison:
In many respects, Aptos looks more like Helvetica if you look close, particularly at some of the symbols as well as letters like lowercase 'a' and 's'. However, one of the specific issues which motivated the switch to Aptos was that most all the popular fonts, particularly the sans serif fonts, was that it was impossible to tell the difference between a lowercase 'l' and an uppercase 'I'. The Aptos font (if you check the examples fonts above) addresses that.
Irvine, CA
Siemens PLM:
Irvine, CA
Siemens PLM:
