Not sure because some types of tires have the 'snap-thru' problem: Mx can be held close to zero, but then it leaps to it's conventional preference. Can make a LOUD BANG on a tire test machine ! So this drastic change in roll moment can cause a rollover in SUVs. I have a video that shows a Saturn View breaking a rear control arm because of it.
Next, with +-6 deg of camber change, the wheelhouse has to be made larger to fit the new steer & camber displacements. Friendly rub ? I don't want anything rubbing my sidewalls. I suppose you'd want to go back to bias belted tires in order to make the camber thrust worthwhile. Maybe on race tires because their 'racing radials' are actually bias ply sidewalls. Just burn one in a fire pit to see how they look without the camo rubber.
So, toe is the only dynamic d.o.f. I'd vote for. Only need ONE actuator (ignore the offset steering wheel spokes). Tire wear, maybe some fuel economy because of residual forces & moments, squeal in the parking garage, and a few extra decimals at max lat if you vote for anti-Ackermann. RW steering made the most sense to me for response time reduction and turn circle, especially for pickup trucks pulling bumper hitch trailers whose owners could not afford the better gooseneck hitch option. But GM couldn't give it away. Plus the Safety Jihadis forbid using more than a few degrees of toe change, when the real advantage came when 3 - 4 times that made it awesome.
What do you think about steer by wire and steer augmentation via 4 wheel traction motors ? Tire wear, durability, cost, parts inventory, and Crash Safety are the winners here (IMHO). We put hundreds of peeps way up in the air with SBW controls on a plane that has a few extra degrees of freedom to manage and nobody kicks the tires. You mostly never hurt people in a plane crash. Killing them seems like the least costly option.
