GregLocock
Automotive
- Apr 10, 2001
- 23,788
So here's Honda's explanation, I've bolded the bit that sounds like BS
The steering gear contains a unit that includes a worm gear and a worm wheel. Honda stated this condition
of momentary increase in steering effort occurs due to two factors within this unit. During manufacturing, the
worm wheel goes through annealing and component conditioning processes. These processes caused
internal stress and strain within the worm wheel. This strain was slowly released over the first few months of
the vehicle life. Over time, the released strain caused the deformation of the teeth on the worm wheel,
causing the worm gear to catch on the worm wheel. This results in the consumer’s momentary increased in
steering effort. Also, the manufacturing process did not guarantee consistent grease application and
therefore, some vehicles within the scope received too little grease which contributes to the momentary
So they are claiming the worm distorted enough in a few months due to internal stress relief that all the clearance between the two gears was used up. I'm no tribology expert, but the missing grease sounds far less unlikely.
Awesome in depth report (not) here
I'd add 2.4 lb of effort at the rim is roughly 5 Nm of steering wheel torque, which is almost the maximum you see in daily driving (6 or so). Perhaps that is not where they measured it, but the whole thing reeks of sanitisation.
Cheers
Greg Locock
Cheers
Greg Locock
