pipe header size for pump running paralel
rudiawan .
Petroleum
ID
i have a project which will using 4 pumps running parallel, the capacity for each pump is 500 m3/hr
the pump will supply the water to the header and then goes to pipeline.
my question is why my client request to use the pipe size of header , 1 size bigger than the pipeline, even tough as per calculation, velocity still on the range
thanks in advance
Define the sizes of the pipeline, header and connecting pipes.
But easier to ask the client....
Your client believes it will help balance the flow rates going to each pump.
It will also be easier to add a pump or two in the future.
To the Client, one possible reason for having a larger pump discharge header may be for new additional pipeline branch in the future.
For all 4 pumps at 2000m3/hr, header size could be DN500 or DN450. If the collection header is short, DN450 may be okay.
I would believe that it is to minimize the impact of the header on the backpressure.
Don't lose your time with this kind of question, the client is the one who pays the bill!
Agree with George and 1503-44 and better distribution to cells.
I guess you have more interesting issues to solve in your plant.
Pierre
Headers are so short that even if the pressure drops per unit length are very much different, there is little effect on total pressure drop in the header. Direct consequences of velocity however, such as erosion and noise, can be far more concerning. The short header lengths of a larger diameter don't cost very much either. What is the problem that's worth aggrevating your client. He already said yes.
Going way, way back to the stone age ... when I used to design piping systems along with Fred Flintstone ..
There was a general rule of thumb for, what was called "collection manifolds"
1) Make sure that the manifold cross-sectional area was equal to or greater than the area total of all inlet piping
2) It's not a bad idea to make the manifold slightly thicker wall thickness/Schedule than the inlet piping
(We would ride around Dinosaurs during lunch break ..)
MJCronin
Sr. Process Engineer
That's a good method, but may result in a large diameter header, if there are a lot of outlets, or if all outlets do not function/flow at the same time.
Well...What methodology do you propose, 1503-44 ?..... or do you just criticize the suggestions of others ?
Did you not see where I stated that this was a "general rule of thumb" ? ... Do you understand what that means ?
MJCronin
Sorry to suppose that you had such bad Monday.
1503-44 said:
"That's a good method"
Our OP has started 10 threads and only posted 4 replies, so I'm not expecting any more information...
One thing to consider though is the size difference of the header and the branch and the construction detail. If you're using weldolets, you often need to be two or more sizes down from the header to avoid bending the header. So say a 12x6 header branch is ok as a weldolet, but not a 12 x 8 or 12x 10 when you really need reducing tees which cost more and take longer to weld.
