RUS Bulletin 1724E-200
stevenal
3,855
Says to add two bells for dead-ends, but fails to indicate why. It goes on to speak of leakage distance, explaining the horizontal strings wash better and are less susceptible to contamination leakage, so this does explain the difference. Does anyone know why to add bells at dead-ends, and does this translate to additional length, leakage, and/or BIL when selecting polymer suspension insulators? Thanks.
Thanks. From your link:
Eepower said:
A tower represents a discontinuity to the traveling waves of current and voltage circulating through the ground wires, whereby these waves are reflected and refracted.
Eepower does not appear to make a distinction between tangent and dead-end structures here. ??
I should note that RUS says to add a bell for angle structures, where conductor tension pulls the insulators away from the structure.
