Failed to set Excel Running - NX 12
Eduardo_Mattos
1
I appreciate if I can have some help to make my NX12 work properly with Excel. I´m stucked two days trying to fix it.
The Siemens NX12 version and now Excel 2010 (32 bits)are installed. I was trying to model a part family when the following message prompted:"failed to set Excel running".
The following actions were done/checked:
1. Availability of the add in in the Excel (option\add in). It is listed there but when I checkmark it and press "ok" buttom, appears a message from windwons pointing opening prevention . I turned off the protection options but it didn´t solved;
2. Excel 2010 - 32 bits installation, following some advices found in the internet, warning about this for NX12 version;
3. Add in "ug.xla", proper directory place (c:\programfiles\Siemens\NX12.0\UGII).
Thanks in advance!
I don't remember which version, but at some point they stopped using "ug.xla". If you are on maintenance, I'd suggest searching the support center for your error text to see what turns up.
www.nxjournaling.com
