Flexible damper winding jumpers
Dear All,
I have seen some OEM use flexible jumpers for connecting the damper winding of the synchronous motors/generators (see attached pictures). I would like to know your inputs of what should be the justification for such design.
Thanks in advance
Petronila
Thanks in advance
Petronila
RE: Flexible damper winding jumpers
Ohm's law
Not just a good idea;
It's the LAW!
For rings that require compensation for centrifugal forces, the orientation of the "joint" would be in the other direction, allowing the ring to "flex" radially. More commonly, an extra retaining ring (or rings) of some non-magnetic material are used to keep the shorting ring from excessive radial motion.
Converting energy to motion for more than half a century
Muthu
www.edison.co.in
