Centreless grinding of end flat shaft
RanaAq
Automotive
PK
Hi, we are facing problem to centreless grinding the shaft with slot at one corner that covers 70% of the round area. The shaft dia is 16mm. Shaft jumps out of the work rest when wheel grinds. Kindly help to give a solution for smooth grinding of this shaft like 1500 shafts in 8 hrs.
 https://files.engineering.com/getfile.aspx?folder=ae4ba542-027a-4950-8b14-ccd116a0f1f5&file=16989876198636195605041468345742.jpg
