thread391-504505
The response from a specialist steam surface condenser vendor with regards to tender (RFP) for design &fabrication of Steam Surface Condenser
1"We will not provide thermal & mechanical calculations.These are proprietary documents and we do not submit to client." Is this correct?
2."Carbon steel tubes are not used in vacuum shell side service." But SA 214 tubes are mentioned in HEI standards.Is there any issues with using SA214 CS tubes for SSC?
DV
DV
