OSUCivlEng
I am doing some analysis of a bridge that was designed in 1961 and am trying to understand the braking loads that were used for design at that time. I have the 17th edition of the standard specs and it states to use 5% of the live load for the longitudinal force. I dug up the 5th edition from 1949 and it states the same thing, so it doesn't appear that this load changed much in 50 years.
Does anyone have access to the 7th edition, which was published in 1957? My hunch is that it is exactly the same.
