Help Catia's dimensions do not correspond to reality
Opua
Automotive
IT
Hello everyone, I realized that Catia's dimensions do not correspond to reality. As the dimensions increase, the error increases accordingly, I can't understand if it depends on the settings relating to the drawing or the model. Can anyone help me to solve this problem?
Many thanks in advance!
What are you measuring, a plotted drawing or something on the screen? If it's a plotted drawing, there can be only one of two issues, either the drawing was NOT plotted 1:1, or what you have is a manually entered dimension. Now I'm not familiar with Catia, but with the systems that I've worked with, there was a way, thought it was generally frowned upon, where the user could edit the text of a dimension creating a non-scale dimension or manual dimension. That being said, we also had tools where by we could interrogate a drawing to see if there were any dimensions which had been edited in this manner.
Did you check any of the other dimensions? If this is the only one that doesn't match your measurement, then it would seem that you're dealing with a manually edited dimension.
John R. Baker, P.E. (ret)
Irvine, CA
Siemens PLM:
rule: DO NOT SCALE DRAWING
that said if you need a drawing to be scale 1:1
[ul]
[li]make sure the view is scale 1:1[/li]
[li]the printing is also scale 1:1[/li]
[/ul]
Also make sure dimension are not fake or rounded... check the dimension value in 3D if it is projected geometry.
Eric N.
As others have said, either the plot settings are wrong, the scales are wrong (view and/or drawing), or that's actually a fake dimension. This thread covers how to find fake dimensions in Catia: thread560-447783
Guys, I checked, the printer was not set to 1/1.
Thank you very much!
