How to rename Catia Bodies with Unique names
nainh
Automotive
MY
Hi mates, may I know how can I rename a Bodies in a Part with unique names? As attached in the picture, I have multiple bodies with the same name (D14-d4)that I want to rename uniquely as D14-d4.1, D14-d4.2, D14-d4.3,...respectively.
I have tried searching for many renaming macro but I've yet to find one that does what I'm trying to do here. Appreciate if someone can point me to the right direction.
I would perform following steps:[ul]
[li]set up a dictionary with unique body names[/li]
[li]search for each entry of the dictionary[/li]
[li]for all hits, loop and rename[/li]
[li]step to next [/li]
[/ul]
regards,
LWolf
I have this to rename the bodies uniquely. For example, I have 5 bodies named A & 3 bodies named 3A, then they will be renamed as: A.1, A.2, A.3, A.4, A.5, 3A.1, 3A.2, 3A.3.
The code can run without error, but nothing happens[sad]. Did I do something wrong here?
Sub RenameBodiesWithCounts()
Dim doc As Document
Set doc = CATIA.ActiveDocument
If doc Is Nothing Then
MsgBox "No active document found. Please open a CATIA Part document.", vbExclamation
Exit Sub
End If
Dim part As Part
Set part = doc.Part
Dim bodies As Bodies
Set bodies = part.Bodies
Dim bodyNames As Object
Set bodyNames = CreateObject("Scripting.Dictionary")
Dim body As Body
For Each body In bodies
Dim name As String
name = body.Name
If bodyNames.Exists(name) Then
bodyNames(name) = bodyNames(name) + 1
name = name & "." & bodyNames(name)
body.Name = name
Else
bodyNames(name) = 1
End If
Next
MsgBox "Bodies renamed with counts.", vbInformation
End Sub
your code just completes step one... bodynames dictionary contains now all the unique names
Code:
Sub CATMain()
Dim doc As Document
    Exit Sub
End If
Dim part As part
Set part = doc.part
Dim bodies As bodies
Set bodies = part.bodies
Dim body As body
    Dim name As String
    name = body.name
    If Not bodyNames.Exists(name) Then
        bodyNames.Add name, 1
    End If
Next
End Sub
use each entry of the dictionary to complete the other steps :)
regards,
LWolf
Working code:
Code:
Sub CATMain()
Dim doc As Document
    Exit Sub
End If
Dim part As part
Set part = doc.part
Dim body As body
    Dim name As String
    name = body.name
        bodyNames.Add name, body
    End If
Next
Dim i As Integer
Dim sel, selString, dictKeys()
Set sel = CATIA.ActiveDocument.Selection
For i = 1 To bodyNames.Count
    dictKeys = bodyNames.keys
    selString = "(Name=" & dictKeys(i - 1) & " & 'Part Design'.Body);all"
    sel.Search selString
    If sel.Count > 1 Then
        For k = 1 To sel.Count
            sel.item(k).Value.name = sel.item(k).Value.name & "." & k
        Next
    End If
Next
End Sub
regards,
LWolf
