Composite stuck to mdf mold
I have been trying to make a reasonably large composite piece and each time I have attempted it. The composite has gotten stuck to the mold. For reference, the first time I made it, I used spray adhesive and that was the main issue. This time, I didn't use it but the part still seems to be very well adhered to the mold.
I was wondering if anyone has any idea why this might be occurring or would be able to offer any assistance with regards to its removal.
RE: Composite stuck to mdf mold
What is the composite material? Prepreg or wet layup?
Cure temperature?
Fiberglass. Wet-layup and then vacuum bagged. Cured at room temperature.
Are you reapplying wax and PVA before each layup / cure?
Are you sure you cleaned off any residual resin before reapplying release?
Can you pop up a corner of the part with a wedge?
Perhaps the resin is shrinking during cure locking it to the mold?
Have you made this cone part on this tool successfully before?
Is the top of the cone open so maybe you can rig up a tool to hold the part and press out the mold from the top?
I tried to at first and had to use an adhesive that held it at the top but it was hard to remove from there but the bottom came out perfectly. I had to angle grind it out though, the upper region I mean.
I'm going to attempt drilling holes in the bottom and pushing it out with rods similar to what you mentioned. I think if I need to, I'll also remove the top of the cone mold too.
I think this would have been mitigated if I made a two part mold but I didn't anticipate this level of difficulty.
Wait, is the mold inside or outside of the cone (part)?
It's on the inside of the mold.
The thing is the mold is huge and extremely heavy. I'm going to attempt that though somehow.
Why? If you have a part (or even just a mockup form) that works, make a fiberglass mold from it (put release agent on the part, then lay up fiberglass over it).
