Hi
We have a problem with Lenze 18kw vsd model ESV183N04TXB suffering output module failure.
The system is composed of two 15kw fans installed in series and each has an 18kw inverter controlling it.
These fans always work toghether.
Normal running operation is at 35Hz when CO sensors reach a certain level and 50Hz when there is a signal from the fire alarm.
Can you please advise if operating fans in series in this way can have any adverse effect on the vsd
Frank
Frank
