Ansys additive error
Ahmed_abdelgawad
AE
I am currently trying to simuate 3D printing using Ansys WB.
after setup the model i get
"the time to apply the heat is greater than the time to cool down the layer. this indicates a units problem or inconsistent input values. check your material properties, part size, mesh height, etc"
Knowing that the same setting worked previously.
your help is much appreciated.
Thanks in advance.
