CNC Programming Left Hand Right Hand
drawoh
CA
If I prepare a machining drawing tabulated left hand and right hand, can a CNC programmer take advangtage of this, or do they have to write two programs?
JHG
Fanucs have a mirror function about the x and/or y axis. I suspect most VMC controllers have this.
I wonder if it applies to generated threads. I always looked forward to someone putting LH threads in the opposite hand part.
drawoh said:
can a CNC programmer take advantage of this
Every machine controller I've ever touched has had mirror functions, and so has every CAD program. I've done this a bunch and never had an issue with having to rework things for a left hand part.
It can - smart programmers will set up generated threads as a subroutine anyway, in which case they would not be mirrored.
Inspectors should fail parts until engineers put an explicit note "OPPOSITE EXCEPT SCREW THREADS."
Time to start that revolution!
