Abaqus Error Node
RAGTS
Bioengineer
Currently I have a model with a cantilever based indenter that will move into a tissue. Whenever I run the model, I get the following error message:'UNABLE TO LOCATE NODE SET ASSEMBLY_INDENTER-1_INDENTER-1-REFPT_. THE NODE SET MUST HAVE BEEN PREVIOUSLY DEFINED.'
What do i do about this?
Check that reference point, it might be incorrectly attached to the indenter and may require redefining.
