Problem with F8 button on New Laptop in NX 2007 1
Jashe
Automotive
Jun 19, 2013
206
The F8 button isn't orienting the part to the nearest surface on he new laptop like it did on the old one. Is there a way to fix this?
On some laptops you have to hold the [kbd]Fn[/kbd] key to get them to work; otherwise they default to some other function such as volume control or screen brightness.
www.nxjournaling.com
You can usually toggle this functionality in the manufacturer-supplied app or in the laptop BIOS, so that you won't have to press fn every time you need to use an function key.
